diesel P1196 error
DTC P1196:00​
Key off voltage high​
DETECTION CONDITION​
• The PCM monitors the voltage from the main relay. If the voltage is more than 10 V when the ignition is switched off, the PCM determines that there is malfunction main relay circuit.
Diagnostic support note
• The MIL does not illuminate.
• The DTC is stored in the PCM memory.​
POSSIBLE CAUSE​
• Main relay connector or terminal malfunction
• Main relay malfunction
• Short to power supply between main relay terminal D and PCM terminal 2C/2F
• PCM connector or terminal malfunction
• PCM malfunction​
