diesel SCBS a chyba 9
Cipik
Zdravím, krok od kroku se po generálce motoru, podařilo nastartovat a vše šlapalo jak má. Jenom svítí SCBS inspection required (okno je čisté), bez kontrolky motoru. Diagnostika ukázala p2299 spínač brzdového svetla/ senzor akceleračního pedálu, ale auto jede jak má, nic nemá prodlevu. Tak bych se chtěl zeptat, jestli byste neměli nějaký tip po čem jít
DTC P2299:00​
Accelerator pedal: spring back malfunction​
DETECTION CONDITION​
• The brake pedal is depressed for the specified time* or more when any of the following conditions is met with the accelerator pedal depressed.
While driving vehicle:
― Accelerator pedal opening angle: 5% or more from fully closed
― Vehicle speed: 10 km/h {6.2 mph} or more
― Engine speed: 1,150 rpm or more
While vehicle is stopped:
― Shift lever position: neutral (MTX)
― Selector lever position: N position (ATX)
*: Specified time is 0.6—10 s according to braking force calculated in PCM.
Diagnostic support note
• This is a continuous monitor (other).
• The check engine light does not illuminate.
• FREEZE FRAME DATA/Snapshot data is not available.
• DTC is not stored in the PCM memory.​
FAIL-SAFE FUNCTION​
Not applicable​
POSSIBLE CAUSE​
Note
• If the brake override system operates, the PCM detects DTC P2299:00.
• Driver depresses accelerator and brake pedals simultaneously (during braking operation using left foot)
• Accelerator pedal is pressed in by object such as floor mat
• Accelerator pedal sticking
• APP sensor signal malfunction
― APP sensor malfunction
― Related connector or terminals malfunction
― Related wiring harness malfunction
• Brake switch signal malfunction
― Brake switch malfunction
― Brake pedal malfunction (increase in play due to joint pin wear)
• PCM malfunction​
SYSTEM WIRING DIAGRAM​
Not applicable​
Takže nejrychlejší řešení bude asi kontrolka pojistek a jestli je vše pořádně zapojené?
